front sidelights not working
Hi, I know all my lights used to work correctly but has now failed MOT as the front sidelights are not working. There are no bulb warning messages on the dash, i have tried new bulbs and still not working.
Ive read online that someone had the same issue, where they used to work then stoped, and said he went back to standard coding which fixed it.
Does anyone know what the standard coding for the lights would be, ive been through with VCDS and from what I can see they should work. I have xenons if that effects the coding.
Thanks for any help.
Will
Might be worth posting a VCDS autoscan :)
Silly me!!!!!!!!!!!
Wednesday,29,November,2017,18:57:27:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: TMBUF21Z682212068   License Plate: KU58MFX
Mileage: 181690km-112896mi   Repair Order: 29/11/2017
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 1C 25 37 42 44 46 52 55 56 62 72 76
VIN: TMBUF21Z682212068   Mileage: 181690km/112896miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: Cannot be reached 1100
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1Z0 907 115 D    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH16---    Serial number: SKZ7Z0H4983333
   Coding: 0203000318070160
   Shop #: WSC 73430 790 00000
   VCID: 3663C05341B2A6AE7EF-8063
1 Fault Found:
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0000 0000
Address 03: ABS Brakes (-----)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
   Component: ESP MK60EC1   H35 0104
   Revision: 00H35001
   Coding: 163B601C092300FC680B06EA902100816C00
   Shop #: WSC 73430 790 08192
   VCID: 74E73A5BD74EF4BE80B-8021
1 Fault Found:
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 175
                    Mileage: 181673 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 0
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 50265
                    Count: 1
                    Count: 0
                    Count: 0
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1Z0 907 044 AC    HW: 1Z0 907 044 AC
   Component: ClimatronicPQ35 120 0600
   Revision: 00120022    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 77FD0D5706389FA6A59-8022
No fault code found.
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
   Component: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serial number: 00000005863061
   Coding: E18ECF131004140043110D00000000000009FF0F5C402000000000000000
   Shop #: WSC 73430 790 12345
   VCID: 3365F94752C0B386591-8066
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 110708 022  0601
   Coding: 00055223
   Shop #: WSC 73430
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     160708 054  0402
   Coding: 00471277
   Shop #: WSC 73430
8 Faults Found:
01497 - Bulb for Blinkers; Front Right (M7)
            012 - Electrical Fault in Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 174
                    Mileage: 181671 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.95 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
01834 - Bulb for Side-Blinkers; Left (M18)
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 135
                    Mileage: 181699 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.75 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01835 - Bulb for Side-Blinkers; Right (M19)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 135
                    Mileage: 181699 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 14.25 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02395 - Parking Light Front Right (M3)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 174
                    Mileage: 181671 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.85 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
02071 - Local Databus
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 157
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.40 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
01499 - Bulb for High-Beams; Right (M32)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 174
                    Mileage: 181671 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 11.85 V
                        ON
                        ON
                        OFF
                        OFF
                        ON
01520 - Rain and Light Recognition Sensor (G397)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 16
                    Reset counter: 161
                    Mileage: 178120 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.50 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
02390 - Control / Regulation for Ambience Lighting (E400)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01111001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 135
                    Mileage: 175934 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.30 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD24L2F7
   Coding: 0020788
   VCID: 3D71DF7F648475F6BF5-8068
   Subsystem 1 - Serial number: 6332MSME3D330958F
   Subsystem 2 - Serial number: 6342MSME39234E5CO
1 Fault Found:
00532 - Supply Voltage B+
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 CA    HW: 1K0 953 549 CA
   Component: J0527           051 0101
   Coding: 0000042
   VCID: 73E539471240F386991-8026
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1Z0 920 942 C    HW: 1Z0 920 942 C
   Component: KOMBIINSTRUMENT VD1 1612
   Revision: V1612037    Serial number: SKZ7Z0H4983333
   Coding: 0007401
   Shop #: WSC 59758 001 1048576
   VCID: 387FCE6B4BA650DE6C3-806D
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K086300543
   Coding: E9817F0E4012022303
   VCID: 3561C75F5CB4ADB6775-8060
1 Fault Found:
00484 - Vehicle Position Recognition Control Module (J603)
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 120
                    Mileage: 175934 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 15:10:44
Address 1C: Position Sensing
Cannot be reached
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VD1 1612
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 B    HW: 1Z0 035 680 A
   Component: RNS-MID       H04 3814
   Revision: AB001001    Serial number: SKZ6Z7H5209053
   Coding: 06000400040100000000
   Shop #: WSC 26029 576 92321
   VCID: 2F6DF5377EE897663D9-807A
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 H    HW: 1T0 959 701 H
   Component: Tuer-SG         006 1204
   Coding: 0000756
   VCID: 3C77D27B7F9E7CFE88B-8069
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 74     2301
   Revision: 00H15000
   VCID: 2A5BE423850AF24EEA7-807F
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0204
   Revision: 00020000    Serial number: 00000000000000
   Coding: 91801A085283007F3F02050FC0085F96907C00
   VCID: 8305E987C2E04306091-80D6
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 73430
   Subsystem 6 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H08 9001
   Subsystem 7 - Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 H    HW: 1T0 959 702 H
   Coding: 0000756
Address 55: Xenon Range        Labels: 1T0-907-357.lbl
   Part No: 1T0 907 357
   Component: Dynamische LWR      0003
   Coding: 0000007
   VCID: F4E7BA5B974E74BE00B-80A1
3 Faults Found:
01539 - Headlights Not Adjusted
            005 - No or Incorrect Basic Setting / Adaptation
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
01533 - Terminal 56 (High Beams)
            011 - Open Circuit - Intermittent
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 377DCD5746B85FA6659-8062
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
End   ---------------------------------------------------------------------
I did have the o/s lamp out to change the bulb. Think the faults do clear down but battery went flast on laptop. :angry:
