Warning lights come on and fault codes come up
My fabia did this again today, started engine, drove off and lots of lights came on the dash including power steering, handbrake, abs, asr and maybe a few others cant remember, was also beeping at me. So i turned it off and restarted and it was fine again. This is the 3rd time it has happened now so thought i should investigate. VCDS scan came back with following:
(ignore the airbag communication issue, thats because I haven't reset the module after unplugging the switch, and also the issues with the HVAC flaps)
Car has a new battery and is charging properly which was my first thought.
Anyone know what it might be?
Chassis Type: 6Y - Skoda Fabia I
Scan: 01,02,03,08,09,15,17,19,25,37,44,46,55,56,76
Address 01: Engine       Labels: 038-906-019-ASZ.LBL
   Controller: 038 906 019 NF
   Component: 1,9l R4 EDC G000SG  7000
   Coding: 00102
   Shop #: WSC 13765
   VCID: 68A39A671B6B
   TMBWU46Y454338987     SKZ7Z0E2945833
1 Fault Found:
18057 -  Powertrain Data Bus: Missing Message from ABS Controller
            P1649 - 35-10 -   - - Intermittent
Readiness: N/A
Address 03: ABS Brakes       Labels: 6Q0-907-37x-ABS.LBL
   Controller: 6Q0 907 379 AB
   Component: MABS 8.0 front  H03 0001
   Coding: 0000008
   Shop #: WSC 13765
   VCID: 7D8DDB3364E9
2 Faults Found:
01314 -  Engine Control Module
            004 -  No Signal/Communication - Intermittent
01321 -  Control Module for Airbags (J234)
Address 08: Auto HVAC       Labels: 6Q0-820-045.LBL
   Controller: 6Y0 820 045
   Component: Klimaanlage        X0840
   VCID: F297780FADB7
5 Faults Found:
65535 -  Internal Control Module Memory Error
            00-00 -   -
01596 -  Motor for Outside/Recirculated Air Flap (V154)
            30-10 -  Open or Short to Plus - Intermittent
01271 -  Positioning Motor for Temperature Flap (V68)
            29-10 -  Short to Ground - Intermittent
            09-00 -  Adaptation Limit Surpassed
            55-00 -  Adaptation Not Successful
Address 09: Cent. Elect.       Labels: 6Qx-937-049-B.LBL
   Controller: 6Q1 937 049 D
   Component: 0000 BN-SG.         1S34
   Coding: 26042
   Shop #: WSC 13765
   VCID: 3C0B16373F73
1 Fault Found:
01316 -  ABS Control Module
            49-10 -  No Communications - Intermittent
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Controller: 1C0 909 601 A
   Component: 0S AIRBAG VW51      0008
   Coding: 12371
   Shop #: WSC 13765
   VCID: 1E4FFCBF89AF
No fault code found.
Address 17: Instruments       Labels: 6Y0-920-xx0-17.LBL
   Controller: 6Y0 920 971 Su
   Component: KOMBI+WEGFAHRSP VDO V02
   Coding: 28401
   Shop #: WSC 00046
   VCID: D7C1299B2615
1 Fault Found:
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   Controller: 6N0 909 901
   Component: 003D GATEWAY CAN    1S34
   Coding: 00014
   Shop #: WSC 13765
   VCID: F0937207A3BB
1 Fault Found:
Address 25: Immobilizer       Labels: None
   Controller: Bit teA dre ssu
   Component: e 17 eingeben
   VCID: CFD1D1FB1EC5
No Faults Found
  or DTCs not supported by controller
  or a communication error ocurred
Address 44: Steering Assist       Labels: None
   Controller: 6Q0 423 156 AB
   Component: LenkhilfeTRW        V270
   Coding: 10120
   Shop #: WSC 13765
   VCID: 6F91F17B3E85
Address 46: Central Conv.       Labels: 6Q0-959-433.LBL
   Controller: 6Q0 959 433 E
   Component: 60 Komfortgerát     0002
   Coding: 00019
   Shop #: WSC 13765
   VCID: 3D0D1B332469
Address 55: Xenon Range       Labels: 6N0-907-503.LBL
   Controller: 6N0 907 503
   Component: Leuchtweiteregelung 0005
   Coding: 00010
   Shop #: WSC 13765
   VCID: ECAB66778F93
End   --------------------------------------------------------------------------------------------------
Edited by clarendon462
hair line crack in the ABS main fuse on top of the battery??....or break in ABS main wiring by connector?
Edited by fabdavrav
I've had a good look at the fuses and they seem fine.
ABS wiring will be next to check. Will have to remove airbox i think to get access.
Agreed
Wiring issue most likely.
The connections in and around the battery and they are bad for main earth leads for corroding at joints
Thanks for the replies, tomorrow will see if i can remove the earth and clean it up, then check over the wiring to the abs
Strange as car drives absolutely fine when warning lights arent on. ABS still functional afaik.
Mine does this but ive no faults in mine.
