25w 2000Lumens Xenon Retrofit
Anyone done it?
Was just about to spend £100odds on 2 Osram ones, when I realised that, with everything, including the bulb being built into the ballast, that 1. there might not be enough room to fit the bugger, and 2. If I break the bulb during fitting, I am another £50odd squiddly diddly's as the whole thing will need to be purchased again.  I will have a look on Monday when I am off and check the space but was wondering if anyone had done it.
I haven't fitted these. But I have fitted aftermarket ones.
Those ones I think you should remove bumper and headlight and fit them off the car! I did that with these as you get total access
