Haldex problems scout
Following the none starting issue aa been out it was a fuse the ones in the dash number 6 keeps blowing and no ignition lights and no dials work says in the book instrument cluster
Control unit for automatic gear box it doesn't have one
Power steering unit
Parking aid
A nd haldex clutch
All I done was remove motor and oil clean the filter and replaced it was a bit stuck on so few taps with a hammer to loosen what could I have disturbed to cause this issue
@Lorrigirl29 - Well, if a fuse has blown, replace it once because they get old too. If it blows again then you may have a problem but not one that's easily diagnosable across the interweb.
Aa been out done a diagnostics  and haldex pump was on the
Report
