Upgrading Rear Brakes
Hello guys,
I was wondering how are you satisfied with your brakes?
I was thinking about upgrading especially rear brakes, did any of you did this?
Tnx
I use EBC Yellow pads for many years, initial bite is average but they brake much better once pressed firm and have not faded on me yet. I had stock pads fade as well as stock brake fluid boil in the past, pads on the Mk1 Octy and fluid in the Superb. Since then I use Castrol Response Super Dot 4 fluid and EBC green or yellow pads, yellow DP4680R for rear if I recall correctly.  If you want even better brakes, I guess for larger discs you would need to find fitting carriers from some 2WD Audi or a Passat.
Edited by dieselV6
Tnx, I will try to use better pads than OEM, and see what happens from there.
