Battery dying
@snowathlete S/S won't always work for a lot of different reasons.
Especially if there is high power consumption, A/C is on, low temp outside, etc.
The stop / start system is quite a complicated process with a varying number of influences...
Conditions for the automatic engine shut down (stop phase):
  • The gearshift lever is in Neutral.
  • The clutch pedal is not depressed.
  • The driver has fastened the seat belt.
  • The driver's door is closed.
  • The bonnet is closed.
  • The vehicle is at a standstill.
  • The engine is at operating temperature.
  • The charge state of the vehicle battery is sufficient.
  • The stationary vehicle is not on a steep slope or a steep downhill section.
  • The engine speed is less than 1200 1/min.
  • The temperature of the vehicle battery is not too low or too high.
  • There is sufficient pressure in the braking system.
  • The difference between the outdoor- and the set temperature in the interior is not too great.
  • The vehicle speed since the last time the engine was switched off was greater than 3 km/h.
  • The front wheels are not turned excessively (the steering angle is less than 3/4 of a steering wheel revolution).
Conditions for an automatic restart (start phase):
  • The clutch is depressed.
  • The max./min. temperature is set.
  • The Defrost function for the windshield is switched on.
  • A high blower stage has been selected.
  • The START STOP button is pressed.
Conditions for an automatic restart without driver intervention:
  • The vehicle moves at a speed of more than 3 km/h.
  • The difference between the outdoor- and the set temperature in the interior is too great.
  • The charge state of the vehicle battery is not sufficient.
  • There is insufficient pressure in the braking system.
