scuttle water drainage
When investigating water leaks into the passenger side of our Yeti I noticed that the scuttle drain holes were blocked so water was overflowing. I cleared these but noticed that there are no drainage tubes fitted so the water effectively takes the same route as the overflow. Has anyone noticed if they have drainage tubes fitted to the scuttle? Nb. the sunroof drainage tubes were replaced early on due to kinking during the build.
Many thanks
Mike
blocked drain holes - never had this problem Mike
