Vrs front passenger door jammed shut
Seems my passenger front door is stuck closed. All other doors fine with key fob but passenger door does not budge. Tried pulling handle inside but pin keeps going back in. Any ideas??
Sorry for this but have you tried to lock and unlock from the lock switch inside the car?
Tried Double clicking the fob?!
Tried both them things
Sorry but have you tried with the key in the lock?
You'll have to take the door card off and replace the lock mechanism, it's deadlocked and nothing will budge it until you smash the old lock open and disengage the deadlock, it's a tricky and time-consuming job and you'll need somewhere dry and sheltered to do it.
Cheers for reply. I've got a mate with garage so I'll use that and see if I can sort it myself. I'm ok mechanical wise
The fonzie method got my passenger front door open when my lock mechanism failed. A gentle thump just below the exterior handle whilst pressing the key fob did the trick. made things a sight easier than tackling the job from the inside.
