Heaqd Lamp Fault Code
Hi, I'm looking for some help with my head lamps on my 2011 MKII.
It appeared that the passenger side headlamp began to flicker. Eventually it went out. This would repeat if I redrove the car. Eventually the bulb failed.
Brought a new bulb and instantly had the same problem. Swapped the bulbs over in left and right headlamp to see if problem would follow.
Problem remained in the passenger side.
The head lamp still comes on but again it starts flickering and then around twenty minutes latter it goes out and the car tells you a bulb has gone.
With the bulb gone out I have run VCDS with the following faults shown for the headlamps which is 00987.
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 P    HW: 1K0 937 087 P
   Component: BCM PQ35  H+  104 0615
   Revision: 00104 AF
   Coding: 48990AB8E85BF1C040080080310089E4437000AE732085605C8040000040
   Shop #: WSC 33361 790 00999
   VCID: 3E7382C4A95A8CB1DB-806A
   Subsystem 1 - Part No: 3T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 11041  26  0602
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 250411 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
1 Fault Found:
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 186
                    Mileage: 138209 km
                    Time Indication: 0
                    Date: 2012.06.02
                    Time: 21:40:58
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.45 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
I'm not sure how to cure this. Can anyone help on what to do now please. I have read the ROSSTECH info and I am no wiser.
FULL VCDS readout in case it is of help.
Chassis Type: 3T (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 36 37 42 44 46 52 55 56 62 72
          77
VIN: TMBBF73T2B9065789   Mileage: 138200km-85873miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFGB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 CH    HW: 03L 906 018 BR
   Component: R4 2.0l TDI   H23 9977
   Revision: 42H23---    Serial number:
   Coding: 00190012042500080000
   Shop #: WSC 28060 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018CH 003007
   ROD: EV_ECM20TDI01103L906018CH.rod
   VCID: 72EB66F4A58218D1EF-8026
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 863D6016092800FF611206EC90220082340000
   Shop #: WSC 33361 790 00070
   VCID: 76E35AE4C1EA04F1C3-8022
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 3T0 907 044 BE    HW: 3T0 907 044 BE
   Component: Climatronic   H16 0402
   Revision: 00006001
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 76E35AE4C9EA04F1C3-8022
   Revision: 00104 AF
   Coding: 00D7B7
   Coding: 0730ED
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 186
                    Mileage: 138209 km
                    Time Indication: 0
                    Date: 2012.06.02
                    Time: 21:40:58
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.45 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J791)       Labels: 1T0-919-475.clb
   Part No SW: 3T0 919 475 C    HW: 3T0 919 475 C
   Component: PARKHILFE PLA H08 0005
   Revision: --------    Serial number: 13991109049972
   Coding: 109004
   VCID: 3D7185C8A45C97A9C2-8068
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655 C    HW: 3T0 959 655 C
   Component: J234__LAU VW10 HI   1918
   Revision: 20014000    Serial number: 003K2P7K867C
   Coding: 0016725
   VCID: 4189F93818A4F349A6-8014
   Subsystem 1 - Serial number: 6332MTS607771001
   Subsystem 2 - Serial number: 6342MTS624411011
   Subsystem 3 - Serial number: 6351HTS6RKKDU9KJ
   Subsystem 4 - Serial number: 6361HTS6S74HU9KJ
   Subsystem 5 - Serial number: 63727TS640UPU9KR
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110420201935
   Coding: 008A140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWSXS.rod
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 820000
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 3T2 920 941 H    HW: 3T2 920 941 H
   Component: KOMBI         H20 0420
   Coding: 410F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 3A7B8ED4BD72A091E7-806E
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 230411F2000699
   Coding: 353303
   VCID: 306FACFC630E6AC159-8064
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H20 0420
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6ADB7E948D52D01157-803E
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760     HW: 3C8 959 760
   Component: J810                0801
   Revision: 00002000    Serial number: 00000000000000
   Coding: 0000003
   VCID: 72EB66F46D8218D1EF-8026
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3T0 035 680 A    HW: 3T0 035 680 A
   Component: RNS-MID       H52 2844
   Revision: AB001001    Serial number: SKZ6Z7L6107021
   Coding: 040004020004008100
   VCID: 2E53B284793A7C314B-807A
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   Part No SW: 8X0 959 793 E    HW: 8X0 959 793 E
   Component: TSG FA        H09 0410
   Revision: --------    Serial number: --------------
   Coding: 011D0220DE01001000
   VCID: 4FADCF001EF0153920-801A
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 195    3201
   Revision: 00H20000
   VCID: 3467A0EC571656E13D-8060
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   Part No SW: 8X0 959 792 E    HW: 8X0 959 792 E
   Component: TSG BF        H09 0410
   VCID: 4E93D20419FA1C312B-801A
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0148
   Revision: 00H04000    Serial number:
   Coding: 1377095
   Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000021
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0004
   Coding: 00000021
1 Fault Found:
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 186
                    Mileage: 138209 km
                    Time Indication: 0
                    Date: 2012.06.02
                    Time: 21:40:58
             Freeze Frame:
                    Voltage: 11.36 V
                    Speed: 0.0 km/h
                        ABS 1
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 62: Door, Rear Left (J388)       Labels: None
   Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
   Component: TSG HL        H06 0409
   Coding: 010C00200001001000
Address 72: Door, Rear Right (J389)       Labels: None
   Component: TSG HR        H06 0409
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 5N0 035 730 D    HW: 5N0 035 730 D
   Component: Telefon       009 0511
   Revision: --------    Serial number: 35909603146843
   Coding: 020100000100010000000000
   ASAM Dataset: EV_UHVPremi A01005
   ROD: EV_UHVPremi_A01.rod
   VCID: 2959419848D41B099E-807C
End-------------------------(Elapsed Time: 03:06)--------------------------
As per Ross Tech, a faulty connection / wiring.
The flickering supports this theory.
If you can't see any obvious corrosion or thread bare wires it'll be time to find a trusted local auto electrician...
00978 - Lamp for Low Beam; Left (M29): Open or Short to Plus
Possible Symptoms
  • Malfunction Indicator Lamp (MIL) active
Possible Causes
  • Lamp for Low Beam; Left (M29) faulty
  • Wiring/Connector(s) from/to Lamp for Low Beam; Left (M29) faulty
  • Control Module incorrectly coded
Possible Solutions
  • Check Lamp for Low Beam; Left (M29)
  • Check Wiring/Connector(s) from/to Lamp for Low Beam; Left (M29)
  • Check Control Module Coding
