Octavia vRS (02 model) - rear bumper removal
Hi,
Following a minor bump, one of the factory-fit rear parking sensors has popped out of place inside the bumper. I just need to push it back in to place, but think I need to remove or at least displace the bumper to get to it. There are obviously the screws underneath, and I assume there are more just inside the boot under a plastic cover, but don
Remove the rubbing strip and you will see a metal plae under each side with two nutserts on it. Remove the inner boot lining and remove the bolts that are screwed into these.
5 IIRC screws underneath, and some in each wheel arch.
There is also a centre section between the bumper and bootlip, this unclips, undo the two small screws each side and then you can slide off (inwards) the two trims under the rear lenses. Remove the screws that this reveals.
