change fog light from right to left
Hi,
I moved to Poland from the UK and am working to get the car ready for import and I need to change the fog light to the left. I found this tutorial on here but the pictures are not working anymore.
I figured out the wire (its grey/white as he said) and in principle I only need to change it to the left. Can i just cut he wire and extend it to the left and plug it in the empty (and same position) slot there and what kind of specific wire do i need to get?
Just trying to keep it cheap. Just got second hand EU headlights to replace mine
you just need a length of stranded wire and then scotchlok it into place on that grey/white wire. then strip off a few inches of other end and push into empty slot on left fog connector. You may need to cable tie it in place to stop it coming out.
Any similar size wire to the original will be fine as its only a short length so not too vital that its exact
