Heater Problem and inside lights and airbag light on
Hi guys my superb(08) was not being used for a few months,and i have came across a few problems,heater in car warms doesnt get hot,i have changed the thermostat and still the problem presists,Also none of the inside lights or the steering volume buttoms or station change buttons are working,and i have a airbag light which is on,but no codes are showing up,Anyone know what might be causing these problems.Thanks all
Do you have wet front carpets?
Read the stickied thread lift the carpets it may be dry on top but they can hold a lot of water underneath.
No heat sounds like a mixer flap not opening could be HVAC actuator failed, get the car scanned with a VCDS for codes and go from there.
