Glow Plug Light flashing
Hiya , in the last few months sometimes my glow light starts flashing after start the car and it looses some boost , but if i turn the car off and start again thats it problem gone.. and this just happens once a month ,twice a month  max so ive been lazy to sort it  out:D.
Until recently decided to take it to the garage but they dindt find any error so i brought a cable vcds did a scan and got a couple errors..
ive been searching all over and ive found out that can be  Charge air pressure/temperature sensor but im a newbie to this :biggrin: so if someone with more knowledge could give me your opinion please.
this is my vcds log
Tuesday,20,February,2018,18:34:32:00001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: TMBFL25J7C3144937   License Plate:
Chassis Type: 5J-SK25 (6N0)
Scan: 01 03 08 09 10 15 17 19 25 2E 44 56
VIN: TMBFL25J7C3144937   Mileage: 89880km-55848miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 LN    HW: 03L 906 023 LK
   Component: 1,6l R4 CR td H33 9972
   Revision: --H33---    Serial number:
   Coding: 00114016000500080000
   Shop #: WSC 13765 031 00053
   ASAM Dataset: EV_ECM16TDI02103L906023LN 003010
   ROD: EV_ECM16TDI02103L906023LL.rod
   VCID: 7DF0C168ECF16FAEE1-8028
2 Faults Found:
7380 - Manifold Pressure / Boost Sensor (G31)
          P0236 00 [032] - Implausible Signal
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 3
                    Date: 2000.00.00
                    Time: 00:00:00
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 83 °C
                    Intake air temperature: 11 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 12.536 V
                    Unlearning counter according OBD: 40
                    Charge air pressure: actual value-MAP_MMV: 200.00 hPa
                    Charge air pressure specified value-MAP_SP_MMV: 200.00 hPa
                    Ambient air pressure: 101 kPa abs
                    Particle filter: difference pressure-DIP_PF: 0.00 hPa
7382 - Manifold Pressure / Boost Sensor (G31)
          P0236 00 [096] - Implausible Signal
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Date: 2000.00.00
                    Time: 00:00:00
                    Vehicle speed: 255 km/h
                    Coolant temperature: 81 °C
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 12.988 V
                    Unlearning counter according OBD: 39
                    Charge air pressure: actual value-MAP_MMV: 1170.22 hPa
                    Charge air pressure specified value-MAP_SP_MMV: 1170.22 hPa
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS80.lbl
   Part No SW: 6R0 907 379 S    HW: 6R0 907 379 AB
   Component: ABS8.2 front  H03 0001
   Revision: --------
   Coding: 400100DB007100B6022E00E500D800000000
   Shop #: WSC 13765 790 00053
   VCID: 4E9256A41DD7243648-801A
No fault code found.
Address 08: Auto HVAC (J255)       Labels: 6Q0-907-044.lbl
   Part No SW: 5J0 907 044 C    HW: 5J0 907 044 C
   Component: Climatronic   H08 0103
   Revision: K0000000
   VCID: 2A5A3A3445FF2816F4-807E
Address 09: Cent. Elect. (J519)       Labels:. 6R0-937-08x-09.clb
   Part No SW: 6R7 937 087 K    HW: 6R7 937 087 K
   Component: PQ25 BCM      H27 0532
   Revision: -1------    Serial number: 1009009900
   Coding: 24980B3808C92400922008002C2B08C00000400F60000000020000000000
   Shop #: WSC 13125 000 1048576
   VCID: 4C965CACEFCB162626-8018
   Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  002 3211
   Serial number: --------------------
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  002 3211
   Coding: 020000
   Subsystem 3 - Part No: 5J0 951 172
   Component: DWA-Sensor       03   03 1209
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HORN H11  H11 9005
   Subsystem 5 - Part No: 5J0 951 172
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475     HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0003
   Revision: --H10---    Serial number: 32901205101641
   Coding: 100001
   ASAM Dataset: EV_SK25XParkiAssis2 S01002
   ROD: EV_SK25XParkiAssis2.rod
   VCID: 72EAE254A5AF20D68C-8026
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagT2C H10 0020
   Revision: --------    Serial number: 003GX014GTX6
   Coding: 003243
   ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
   ROD: EV_AirbaVW10BPAVW250_VW31.rod
   VCID: 4A9A5AB4EDBF081614-801E
   Crash sensor for side airbag: driver side:
   Serial number: 3495RRB405L13B6C7GPP
   Crash sensor for side airbag: front passenger side:
   Serial number: 3505RRB405511T2U6HKQ
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 5J0 920 911 D    HW: 5J0 920 911 D
   Component: KOMBI         H03 0305
   Serial number: 00000000000000
   Coding: 420A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_A04_SK25.rod
   VCID: 2958C53848F9230EFD-807C
Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R7 937 087 K
   Component: GW-K-CAN TP20 H27 0532
   Revision: -1------
   Coding: 032300
   VCID: 70EEE85CA3A312C67A-8024
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H03 0305
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6ADAFA348D7FE81634-803E
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Part No SW: 5N0 035 342 E    HW: 5N0 035 342 E
   Component: SG EXT.PLAYER H13 0240
   Revision: A1001003    Serial number: 7661939094
   Coding: 010000
   VCID: 2958C53840F9230EFD-807C
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 10110
   Shop #: WSC 13765
   VCID: 2F6C2B20EA1D4D3E23-807A
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5J0 035 161 D    HW: 5J0 035 161 D
   Component: Radio-SWING   001 0003
   Revision: -----04S    Serial number: SKZ4Z2M1155052
   Coding: 090004000006
   VCID: 2344D71022D5F95EB7-8076
End-------------------------(Elapsed Time: 02:05)--------------------------
@GabrielLF Check the Rosstech Wiki to confirm, but I'm pretty certain that you're getting codes 7380 and 7382 because you have a failing MAP sensor. Kudos points for posting the VCDS log without having to be asked.
Thank you very much Ken. :)
I'm going to try to swap the map sensor tomorrow.
