tail lights
I have a Skoda Fabia and need to change the tail lights.  I took the two screws out as per instructions but manual says I need a tool which is under wheel arch.  Can't find it and don't really understand it.  Can anyone help???:)
Take out the screws and gently pull the tail light out.
There are two plastic tabs which are hold by a clip which you need to pull out.
If you have those plastic removal tools it is way easier.
Hi - you might find the posts at the following thread helpful :
The little metal tool you ask about is with the spare wheel kit. It’s also used for removing the cap to access the  towing eye.
However - a plastic tool,  like those mentioned in above linked thread, will make the job much, much easier.
