Clutch pedal and master cylinder
Tsi 1.8 manual est 2007 140000 miles
clutch pedal does not disengage clutch. Pedal goes to floor very easy and stays there.master cylinder a little damp on engine side . Lower dash off pedal nuts undone.
question how do I remove metal hydraulic pipe . How does pedal return to position, is it pressure from slave cylinder?
any advice about this situation is needed
Hi I have a problem with my clutch as i tried to bleed the system as its been gradually worse to change gear, I now find myself with no clutch pedal at all, bled perfectly until i tried the pedal and it just hits the floor. There are no leaks anywhere in the system, had the brakes done last year just before i purchased, so do not know if it is from that, so with i assume an enclosed slave cylinder how do i get the pedal back or do i just carryout a complete re bleeding of the system.
You should pressure bleed the clutch, experience shows it is problematic if done just using a one man bleeder and depressing the pedal.
I recommend Gunson Eezibleed.
Thanks MicMac great information
I have ordered a new master cylinder and will have a go on Monday
keith_the
Well the master cylinder is fitted without too much of a problem mainly because of the workshop manual information , I would not have guessed a 40mm spacer would allow it to be removed with an anti-clockwise turn and pressure on two lugs at once.
Thanks also to MicMac for the ezibleed which worked well as I have no mates to help and the manual recommends it also.
The pedal feels a little different (weak) and the clutch bites high up but then we have 140,000 on the clock and it may still need another bleed if I get the energy to take the air box off again .
Great help briskoda Thank you.
You are welcome, been there done that, happy to help.
