Failure of screen washers Octavia Estate MkI 2003
Hi. I am really struggling. I can see the cause of the problem with the washer reservoir on my 2003 MkI Skoda estate. A washer pipe has become separated at a joint low down just behind the reservoir tank. I have managed to lift the carbon filter unit and expansion tank away a little and have removed the two plastic screws holding the washer reservoir in place. However, the reservoir itself seems to be trapped between the engine and the metal pressings near the wing. The workshop manual suggests it can just be lifted out but there is way too little space. Can anyone advise please? Thanks very much.
Do you have headlamp washers on your vehicle?.
