Check engine light (controle system for exhaust)
Happy Easter guys!
Yesterday I had a fault on a dashboard. Checking the manual it says it's control system for exhaust. We are away at my parent's house and I'm not sure will I be able to go back home. 200km trip.
Is it egr valve, or something else. My vcds is back home so I can't check it myself. Should I stay here until Tuesday and go to a local garage since monday is a holiday, or it's safe to go home. It's a 2010 3.6 fsi with 170000km on the clock.
I don't know much at all about the 3.6 but it seems that it's often a simple sensor fault rather than a more serious component failure that causes the warning lights to appear.
Just my random thoughts.  Hope you get home safely.
Drefaldwyn
So i used the vcds today, and this is what it showed:
Address 01: Engine (CDV)       Labels: None
   Part No SW: 03H 906 032 GF    HW: 03H 906 032 DL
   Component: SK3.6-FSI-EU5   G   3807
   Revision: 5GH09---    Serial number:
   Coding: 0000175
   Shop #: WSC 33361 790 00076
   VCID: 6CD01FF24F10B72125-8038
1 Fault Found:
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 168903 km
                    Time Indication: 0
                    Date: 2012.07.26
                    Time: 19:35:28
             Freeze Frame:
                    RPM: 665 /min
                    Load: 21.6 %
                    Speed: 0.0 km/h
                    Temperature: 79.0°C
                    Temperature: 22.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.224 V
Readiness: 0000 0000
