Paddleshift steering wheel.
I am looking at a 2009 Octavia combi paddleshift wheel.
Will this work in my 2011 yeti once coded?
Its basically the same as i have in the car with the same airbag and mfsw buttons, except with the paddles.
Any help appreciated.
It has been done before, there is some compatibility issues with the MFSW buttons though, but there should be no reason why you could not use your current ones.
Thanks Gizmo. That was my concern, the buttons and Canbus issues.
I thought the mfsw buttons had to be paddle specific?
try looking at yeti projects i think its under "my marmite yeti "
Cheers Sad555.
FL has a different canbus to pre FL.
I can get the steering wheel i mentioned for not a lot of money and my airbag fits it. Its the canbus  for the mfsw buttons i am looking to confirm.
sorry the  only thing i know about with BUS in it is BUSPASS
You won't be able to use your old switches as they're not pre-wired for paddleshift.
If you find a wheel from the same age as your Yeti (so same CANBUS) in theory, it *should* be fine. You'll need to activate the paddle function on VCDS.
