Dash rattles in the morning
I have had my new fabia just over a month now and have noticed a few rattle/ cracks from the dashboard on my way to work in the morning.
The strange thing is when ive finished work in the afternoon i no longer have the rattle/cracks and everything is quiet.
Then next morning it starts all over again.
Ive sprayed silicone into any gaps where plastic to plastic meet but no difference.
I dont want it to go into the dealership for them to start pulling the dash apart and possibly making new issues.
Anybody else have the same problem and any ideas on what to do.
Yes,
Cold in the morning, stuff shrinks, big gaps = noise.
Warmer in the afternoon, stuff expands, no gaps = no noise.
No.
Only travel in the warm.
Thanks AG Falco
Mine's been doing that for two years intermittently,it soon disappears when it gets warm.
The same here and it is worse in the cold/winter.
Thanks AG Falco
Squeaks and rattles are all part of the fun of owning a Fabia although it's not the only brand that suffers from this. Haven't heard it yet in my Mk 111 but I suspect i will sooner or later and it will be a case of turn up the radio if I do.:D
My Polo was the same for two years. Drove me up the wall along with all the other visits to the dealer for faults. Now got a rattle free Octavia.
  • 4 weeks later...
My monte carlo has a fairly loud buzzing coming from behind the wheel/dash
Used to be random, now it does it constantly on deccelaration and evertime i put the clutch in to change gear.
Anyone else have this?
Edited by Nathanb93
Maybe rock lodged somewhere in engine bay?
Had one on the dogbone mount and it did something like that in a vw up.
Edited by krigl
Maybe but it sounds quite high up and is definitely inside.
Does anyone know where to start with taking the dash apart?
Id rather fix it myself so I know what to do if it comes back
Turn the radio up Nathan. I've been there myself with the rattle phobia, albeit in my younger days. You find yourself chasing one rattle after another. It becomes obsessive.
Plus 1 for turn the radio up :biggrin: it's Fabias way of telling you how well screwed together it is.
When it stops squeaking, you know it fell off!;)
Harry
Maybe check where the low pressure petrol pipe crosses over the AC discharge pipe, I’ve found that for cars without the later fuel line, and so missing a bridging clip, that the fuel line eventually starts to almost make contact with the A/C alloy pipe and makes a noise - and starts to wear the rubber fuel line! Fitting a suitable bridging clip sorts that out then you can move onto the next one!
