[Solved] Better way of using stock amp with after market radio
Hi,
In continuation to my earlier post
I found better way of using stock AMP with after market radio.
Warning: DO AT YOUR OWN RISK. I WONT BE RESPONSIBLE IF YOU MESS UP.
What you need.
1.       Arduino UNO (I think you can use Nano also)
2.       CAN Shield
https://www.dropbox.com/s/lmxbs6dnu5scp1b/MCP2515-CAN-Bus-Module-TJA1050-Receiver-SPI-Module-for-Arduino.jpg
3.       CAN Shield library (https://github.com/coryjfowler/MCP_CAN_lib)
4.       7808 Voltage regulator
Step 1:
Download and extract Arduino IDE and CAN shield library
Step 2:
Connect CAN Shield to Arduino as per below diagram
<img src="https://www.dropbox.com/s/7z3crd6gsj38xmw/Can-board-Pin-Outs.png?dl=0">
Step 3:
Connect  Arduino to PC, compile and upload below code to Arduino
#include <mcp_can.h>
#include <SPI.h>
MCP_CAN CAN0(10);     // Set CS to pin 10
void setup()
  Serial.begin(115200);
  // Initialize MCP2515 running at 16MHz with a baudrate of 500kb/s and the masks and filters disabled.
  if(CAN0.begin(MCP_ANY, CAN_100KBPS, MCP_16MHZ) == CAN_OK) Serial.println("MCP2515 Initialized Successfully!");
  else Serial.println("Error Initializing MCP2515...");
  CAN0.setMode(MCP_NORMAL);   // Change to normal mode to allow messages to be transmitted
void loop()
  // send data:  ID = 0x100, Standard CAN Frame, Data length = 8 bytes, 'data' = array of data bytes to send
  unsigned char stmp0[6] = {0x03, 0x00, 0x00, 0x00, 0x00, 0x00};
  byte sndStat0 = CAN0.sendMsgBuf(0x507, 0, 6, stmp0);
  delay(5000);   // send data per 5000ms
  END FILE
Step 4:
Build 7808 Voltage regulator, as per below diagram
<img src="https://www.dropbox.com/s/vlicyzg3k3a43bn/voltage%20regulator.png?dl=0">
Step 5:
Connect Arduino to car. I placed my Arduino inside amplifier(saved me extra wiring hassles)
<img src="https://www.dropbox.com/s/qb9vfeyu9apava1/amp.jpg?dl=0">
That’s it.. If all goes well you should hear sound from stock amplifier
Edited by virgo79
  • 2 years later...
On 08/05/2018 at 20:47, virgo79 said:
Hi,
What you need.
2.       CAN Shield
Step 1:
Step 2:
Step 3:
#include <SPI.h>
void setup()
void loop()
  END FILE
Step 4:
Step 5:
Use this connection diagram in step 2
https://www.dropbox.com/s/l2dg2v71oxnx3zv/Arduino Connection.jpg?dl=0
