06' VRS Stream Upgrade - AUX In
Hi,
After trawling through threads for the last few days I'm still not sure what route I can take.
All I really want is something modern looking with an AUX in so I can connect my phone to play music.
I've had touch screens,gps etc before but honestly after a week I don't use it so not having the extra options doesn't worry me.
Ideally Double din but single would be fine as long as its plug and play.
I have the basic stream,no parking sensors or steering controls.
Budget is €200 and ideally less.
I was looking at this https://www.halfords.ie/technology/car-audio/car-stereos/pioneer-mvh-av290bt-car-stereo
It would give the option of adding AUX and using the BL for music either.
Any help
Dan
if you have a mk2 with a jumbo box there is an aux in under the arm rest, why not use that ?
Buy a used MP3 Stream for about £40? Buy a 3.5mm jack plug and pins and use the Aux in with your phone or MP3 player. I do this though I suspect a pin has dropped out at one channel buzzes with no output.
If it an older car they had non MP3 Stream players without an Aux in as mine did.
Update:  it was the 3.5mm jack to phono plug cable that had gone bad. Swapped it out and buzzing on L channel has gone. Nice simple fix. For once!!
Think I will do this, it seems like too much hassle to do it any other way.
Thanks for the reply
