octavia 09 cr. control issue
hi guys
i have a problem with my skoda octavia 2009 1.9 tdi
i installed a new staker and did all coding in ecu and steering column.
had error in ecu and sterring column 00895- "cruise control switch(e45)"
i bought another stalker and replace it but same issue and cruise control still does not work.
in the mean while i fitted the first stalker ,the one first fitted on my car, to another octavia 2007 and worked without problems.this means that is something wrong with my car.
i checked another friend car and have same steering controler,same wiring same everything.i did not checked the ecu wiring as is not easy to take off.
anyone had issues like me?
can someone please help me to get it fitted..need to leave in holiday and will need it.
also for mfsw retrofit..i have the steering wheel with mfsw what else do i need?just coding?
thank you
0
