I voided the vcds incorrectly.can you help me?
Hello there. I guess I code it wrong. the front passenger door is not opened when the door is locked, how can i fix it? Vcds . Good forums everyone :)
Without knowing what car you have and what modules are fitted it's impossible IMHO to answer your question.
Please post a full VCDS Auto-Scan and tell what coding change(s) you made to cause the problem.
Do you mean un-locked?
Sounds like you have activated the selective unlocking.
Compare you very first scan (before you made any changes) to your latest scan.
My english is not very good. I already apologize for my mistakes and thank you for your interest. :)  My car octavia 2010 model. I made the coding from the 9.electric module. front passenger door stiffens as doors are locked from inside. I will send the vcds scan within 1 hour to you.
Hello there. I could not write an answer because there was no internet. I just returned from the camp. I am installing VCDS Auto-Scan here. hope we can solve the problem. I believe that this forum will help me.
Mileage: 39480km-24531mi   Repair Order:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBCA21Z9A2026606   Mileage: 39480km-24531miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06A-906-033-BGU.lbl
   Part No: 06A 906 033 KB
   Component:  BSE S71 1.6 2V     2228
   Revision: --H04---    Serial number:
   Coding: 0000071
   Shop #: WSC 73430 790 00999
   VCID: 69DE71EF407D030A0B-803C
No fault code found.
Readiness: 0010 0001
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AQ    HW: 1K0 907 379 AQ
   Component: MABS MK70M          0105
   Revision: 00H32001
   Coding: 0000257
   VCID: 010E494F580DEB4AB3-8054
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3T0 820 047 H    HW: 3T0 820 047 H
   Component: Climatic      130 0203
   Revision: 00005001
   Coding: 0000000000
   ASAM Dataset: EV_Clmiatic A01001
   ROD: N/A
   VCID: 3460D09B9F3F8EE268-8060
No ASAM data for: "EV_Clmiatic" (VW36 *)
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 084 B    HW: 1K0 937 084 B
   Component: BCM PQ35  B   103 0537
   Revision: 00103 AD
   Coding: 46180AB8B041B1C04008008011000024030000AE424D89605C4440000000
   Shop #: WSC 03428 389 45725
   VCID: 2D56C5FF7415DF2A27-8078
   Subsystem 1 - Part No: 1Z1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 27070  22  0601
   Coding: 00DFB7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
3 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 1
                    Fault Frequency: 5
                    Reset counter: 235
                    Mileage: 39486 km
                    Time Indication: 0
                    Date: 2012.12.08
                    Time: 19:51:39
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.80 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00979 - Lamp for Low Beam; Right (M31)
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 5
                    Reset counter: 235
                    Mileage: 39486 km
                    Time Indication: 0
                    Date: 2012.12.08
                    Time: 19:51:41
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.80 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
00907 - Intervention load Management
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 235
                    Mileage: 39486 km
                    Time Indication: 0
                    Date: 2012.12.08
                    Time: 20:20:54
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.75 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q2 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2ET93K
   Coding: 0020786
   VCID: 3D76F5BF64754FAA97-8068
   Subsystem 1 - Serial number: 6332MSME48540F0BI
   Subsystem 2 - Serial number: 6342MSME4865006DE
Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000004
   VCID: 030243474211F95AA1-8056
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 1Z0 920 803 B    HW: 1Z0 920 803 B
   Component: KOMBI         H21 0110
   Serial number: 00000000000000
   Coding: 110B00
   Shop #: WSC 73430 031 00999
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
   VCID: 3362D3879A3189DA71-8066
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H16 5223
   Revision:   H16       Serial number: 4120K096230090
   Coding: E9807F06000202001302
   VCID: 66C47AD351632C7226-8032
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Component: IMMO          H21 0110
   ASAM Dataset: EV_Immo_UD_SVDD_RM09 A03004
   ROD: N/A
No ASAM data for: "EV_Immo_UD_SVDD_RM09" (VW36 *)
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2113
   Coding: 0000244
   VCID: 4898946B3BB71A0234-801C
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 67     2901
   Revision: 00H17000
   VCID: 2F6ADFF7BE19AD3A15-807A
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000244
   VCID: 479A975736A9157A3D-8012
1 Fault Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
            008 - Implausible Signal
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 161 F    HW: 1Z0 035 161 F
   Component: SWING         008 0063
   Revision: 0H001001    Serial number: SKZ1Z2I8254923
   Coding: 050004000001
   VCID: 316ED98F682DBBCA03-8064
1 Fault Found:
03138 - Input AUX IN
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 231
                    Mileage: 39449 km
                    Time Indication: 0
                    Date: 2012.12.05
                    Time: 10:43:28
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0000144
   Shop #: WSC 73430 790 1012551
   VCID: 326CD683AD2B80D27A-8066
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 3362D387523189DA71-8066
