P2002 fault code
Hi
We have a Skoda superb 2018 in and fault code p2002 particulate trap efficiency fault. The car has already had a re-gen but fault has happened again. Has anyone else had this issue? There is a TPI to check all intake connections etc and check egr valve and cooler and also check condition of DPF.
Gary
  • 1 year later...
Hi Garry - I'm having this issue. I'm monitoring regens on VAG-DFP and all seems fine by comparing the behaviour to what others describe about their cars numbers for thier DPF regens. But my engine check light keeps coming back with P2002 fault code. I'm hoping it's a faulty sensor. Was it in your case?
Anyone else with this issue and has some advice on what to do next?
Thanks. Still having 2002 with MIL so will check this out.
You're welcome! ;)
