Will these lowering springs fit my car?
At the description yes, as your Fabia is a NJ.
Previous Fabias were known as 6y for the mark 1 and 5j for the mark 2.
Hope this helps.
Davy
Hope this helps.
Davy
Ahhhh I understand, thank you
On 21/07/2018 at 19:38, TomS98 said:
Probably overthinking this but just want to make sure that these lowering springs fit my 1.0 TSI before purchasing. Any help would be appreciated!
https://www.dpmperformance.co.uk/car-parts/skoda/fabia/eibach-30mm45mm-pro-lowering-suspension-springsfabia-nj-10-12tsi-082014
Do you have a dsg? There are 2 types of springs for the 1.0tsi. I think one set is for the dsg model and one for the manual.
Those in the link look as though they may be for an estate /combi.
As said be sure you are getting the correct ones for your model / engine / gearbox combination.
They aren't for the estate, they are for the hatchback, they are the exact ones I got for my 1.0tsi but I had to give the front axle weight to make sure I was getting the right ones because there are 2 different sets so I'm assuming the other is for the slightly heavier dsg model.
