Alarm horn fault code. How do I fix?
Hi All
I did a scan on the VRS today and there were several faults flagged up including Alarm Horn, ABS, Airbag low voltage etc.
Lots of RED so quite worrying.
I cleared the codes and scanned again. Only one fault is still there at the moment for the alarm horn. How do I fix it??
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0575
   Revision: 00103 AG
   Coding: 48180AB8B05BB1C040080080110001E4430000AE424D8560800440040000
   Shop #: WSC 20014 576 89718
   VCID: 326A98646DDDEBD4E2-8066
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 16120  22  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
1 Fault Found:
01134 - Alarm Horn (H12)
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 107
                    Mileage: 138925 km
                    Time Indication: 0
                    Date: 2012.12.14
                    Time: 13:34:32
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.30 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
ross-techs wiki page is a perfect place to find info on fault codes. The one you have listed can he found here I would suggest that the internal battery is at fault in the alarm siren and you need a new unit. These normally have a service life of around 6 years so if yours is original it will be over due!!
