Fabia Mk1 1.9 diesel - Should I take the plunge?
16 minutes ago, Luke83G said:
Ah ok, I've always used Waxoyl, kept our family Montego Countryman going for 22 years on its original wheel arches!  But will give it a bit of research. Is it applied in the same manner (e.g. lay underneath, spray and get more on yourself...)
Yeah, my parents and grandparents used WaxOyl a lot.  From what I've seen, Bilt Hamber's product seems to out-perform it (if you have a look at the tests on their product page), and also isn't a dirt-magnet.  In terms of application, it comes in a 750ml aerosol (high-pressure, designed to work upside down) that you just spray on in thin coats.  I probably used about 20% of a can doing the undersides of the sills on my Fabia (from the flange to the vertical fold at the exterior - you may want to apply some masking!).  Note - they do 3 versions - S50 (brown, very runny - for cavities), UC (clear, hard, for visible areas - e.g. sills & wheels), and UB ("black", for underbodies)
(FYI, if you've not heard of Bilt Hamber, their products are normally for marine/oil applications, and are ... umm ... "industrial strength")
Edited by martinch
  • Replies 53
  • Views 10.7k
  • My 2004 pd100 passed with a reading of 1.25 , limit was set at 1.5 .  They did check for plate,but not visible.
  • Hi - I have managed to find a 1.9 diesel, but it is in the form of a 2001 VW Golf Estate    Thanks guys for all the help, but I just couldn't find a decent low mileage Fabia Mk1 diesel Estat
  • Hi and welcome Luke, great car powered by a great engine, my wife had a 07 elegence hatch from new and literally cried when she sold it to get a higher driving position  I think in the 11 ye
1 minute ago, martinch said:
Yeah, my parents and grandparents used WaxOyl a lot.  From what I've seen, Bilt Hamber's product seems to out-perform it (if you have a look at the tests on their product page), and also isn't a dirt-magnet.  In terms of application, it comes in a 750ml aerosol (high-pressure, designed to work upside down) that you just spray on in thin coats.  I probably used about 20% of a can doing the undersides of the sills on my Fabia.  Note - they do 3 versions - S50 (brown, very runny - for cavities), UC (clear, hard, for visible areas - e.g. sills & wheels), and UB ("black", for underbodies)
Excellent advice - much appreciated.
I will look into this and have a think about using it.  I like the black rust prevention for the undercarriage as it can also make things look tidier, but I totally get the desire for a clear and harder wearing protective layer for the sills.
I think the art of rustproofing at home is a dying trend, which given the advances in factory rust prevention is inevitable, however you only need to look at some recent-ish Fords and Mercedez to see that rust can still occur!
If you talk to Bilt Hamber, they'll tell you it should be renewed every 3-5 due to body flex manipulating the seams.  I know it's in their interests to say that to move more products, but they seem pretty honest (e.g. they've told me when I wouldn't benefit from buying one of their products...).  I can't say I've seen many rusty Mercedes (not really looking to be honest), but the Mk 1 Ford Ka's ... A pillar and filler cap, it seems.
Edited by martinch
I can't type...
  • 9 months later...
I’ve got a 06 facelifted elegance estate 1.9 has cruise and heated seats done 169k does 50mpg+ everywhere you won’t be disappointed cracking car
