Blues radio replacement, plug and play?
My Blues radio broke. It powers on but no sound. If I turn the volume knob display shows volume level 7, but it won’t change. It also recognizes my phone if I plug it in the USB-port, but no sound still. Resetting a few times used to fix this volume problem occasionally, but now it doesn’t help anymore.
Can I buy a second hand Blues unit and just swap it or does it need some coding or something?
Or can I buy a Din1 adapter and just connect a standard Din1 radio? The car has no steering wheel button or reverse cameras or sensors so a basic radio unit would have all features needed.
Every OEM radio will require coding and component protection removal.
OK. Thank you for the information. So easier and propably cheaper would be a standard din1 radio. Are these plug and play, or do I need to buy extra cables or adapters?
