Brisbane mechanic recommendations?
Hi - any Briskodians in Brisbane, Qld here? Looking for reliable Euro specialist mechanic recommendations to look at my Octavia 1Z 118tsi that’s blowing a bit of black soot on heavy acceleration. Thanks in advance.
I couldn't be much further away, but I still know stuff. Have a look/listen for a popped joint or a cracked hose in the turbo-intercooler-manifold pipes.
Thanks for that, Ken.
Hmm, turbo manifold crack sounds v expensive... I'm hoping it's just carbon build up on the valves. This seems to be a problem in the direct injection engines.
It's much more likely to be in the plastic pipes than the cast iron. It's also the sort of thing you can probably hear and/or see with the hood up and the engine running fast enough to go on boost.
