Komfortblinker cycle doesn't change
Hi there friends!
I have bought a cable with VCDS 17.8.1 on Aliexpress, and it worked perfectly, I was able to enable HHC, fog cornering lights and LED bulbs in number plate.
Now I followed this guide but it just doesn't work. I changed the value from 3 to 5, and after checking it again it says 5, but when I turn the blinker left/right, it blinks only 3 times.
Could someone help me with this?
Thanks!
Briskoda doesn’t normally allow discussion about pirated VCDS systems as they are liable to cause damage to your vehicle (whatever that is) and does nothing to support the OEM cable maker.
In this instance the answer to your question is to reset your headunit but note that I will now lock this thread. :thumbup:
Guest
