Change rear door insulation
Hi,
today I have realised that the rear door insulation is so noisy I can hear a wind in 100 km/h. Is it possible to change and will it solve it? Do you have any experience in this?
thanks in advance
Tamas
Are you sure you hear the  (air)  noise from the back ?
Has the car ever been hit or repaired at that point?
You can inspect the sealing with your eye and compare with other doors .
I had a car in past with similar sound producing and the doors needed re-adjustment after involved in a accident.
There was an accident before I bought it. As I know the front and rear door had to replace.
Can I adjust the door at home or is some special tool necessary?
No I'm afraid it's not something easy you can do at home.
the best is to visit a body repair garage as they will know what should do to sort it.
