Wobbly headlight & broken seat belt buckle
Hey guys,
I've recently grabbed a 2013 VRS and a few issues with it has come to light!
First off, my passenger side headlight wobbles significantly, drivers side seems ok. There's a torx on top of the light but it seems to just be something to hold it a little, as the thread is only about 1cm deep, the torx just seems to drop in which confused me. I also checked the torx that is visible through the top of the front grille and that was also tight as anything. If anyone has any ideas where I can look next, that'd be awesome!
Next annoying issue to solve...   the passenger side 2 pronged seatbelt buckles, what I believe is meant to be holding it in (a spline screw), isn't there, so the entire thing just flaps around and obviously this isnt safe, downside is im struggling to figure out where on earth to get a replacement as i have no clues as to the size or where to purchase :(
Check the bulb is in its holder properly. Mine kept working loose and producing a dancing light on that side. It's hard to get the bulb in with the battery in the way.
I'll give this a check too, but it's physically the entire lamp itself, when driving over speedbumps the lights are flickering up and down as the entire unit is rather loose
