Wind noise/buzz at highway speed
Hi fellow Octavies
I have an annoying noise issue when driven at highway speeds 120-130 km/h. It is a wind buzzing noise from the passenger door/window which only occurs at highway speeds. I have looked for gaps or loss parts, but I found nothing. I found a minor gap in the side mirror which I sealed, but it had no effect. I've also tried given the seals silicone and installed wind deflectors, but still no effect.
Have anyone in here had similar issues?
Nb. If I open the window then the noise stops, or if I press on the window it either stops or the pitch is altered.
Here is a link to a video where I've filmed the noise.
https://youtu.be/Kaw6srSDA34
Thanks.
It happens to quite a few cars and IIRC the way to solve it is to fit new door seals.
Possibly the window seal isn't as well fitting as it was.
Try a strip of electrical tape on the outside over the glass and seal, one side at a time to isolate the problem area.
Be careful not to tape over the paintwork.
  • 2 months later...
Tends to happen as well if the car has had wind deflectors installed and have since been removed...
