1Reg. Light out
Hello one of my bulbs is out on the reg. plate is it an easy change? Do you need any special tools? I looked for a video on YouTube but couldn't find 1 for a Mark 2 fabia. Thanks in advance.
2 types of bulb holder, older type simply has two pozidrive screws to undo, newer type (possibly 2010 onwards) are holders that snap in, use a broad flat screwdriver to lever one of the narrow ends down, use something like a bank card to lever against to avoid damage to paint work. Do other end and then pull the holder out.
Edited by xman
I seem to recall having one screw and then lever the other end out but either way, quite simple. Many folk replace the bulbs with LED whist they are at it. Quite cheap on the 'Bay and nicer in colour, etc to normal bulbs.
If you do, be sure to get canbus error free so as to prevent any warning lights on the dash. (Not had this issue and I have LED's in tail lights, numberplate lights, front side and headlights and interior glovebox, map/entry lights and boot light).
