Help required with VCDS codes
Help required with the below codes that all started to happen after i had a dead battery, this has now been changed and still getting the below errors.  also had one about the alarm which turned our to be a fuse i think but now i get the 4 ways flash but no horn when the alarm is activated.   and help with any of the codes or any help with the alarm horn either fix or where the best place to buy one.
thanks in advance.
Thursday,18,October,2018,16:58:52:30570
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: TMBGJ21Z8B2100228   License Plate: AO60ZGG
Mileage: 65000   Repair Order:
Chassis Type: 1Z (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 906 016 E    HW: 03C 906 016 C
   Component: MED17.5.5       G   5344
   Revision: LCH12---    Serial number:
   Coding: 0000077
   Shop #: WSC 73430 790 00085
   VCID: 214F95C6F8BE8016B43-8074
1 Fault Found:
001674 - ECM Power Relay Load Circuit: (J271)
               P068A - 000 - De-Energized Performance Too Early - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Time Indication: 0
                    Date: 2047.15.31
                    Time: 31:63:63
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 10.0°C
                    Temperature: 11.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 10.668 V
Readiness: 0000 0000
Address 09: Cent. Elect.        Labels: 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 BCM PQ35  H   103 06150615
   Coding: 40000AB8A05BB1C04010008011000124430000AE726D89605C8440000040
   VCID: 387958A28B24E1DE63D-806D
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 03011
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 060111 05
   Coding: 0730ED
   Subsystem 3 - Part No: 1Z0 951 171
   Component: Innenraumuebe
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 68     3201
   Revision: 00H20000
   VCID: 34616C92574C05BE4F5-8061
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
            000 - - - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 97323 km
                    Time Indication: 0
                    Date: 2024.14.15
                    Time: 00:11:30
             Freeze Frame:
                    Battery Volts: 12.2 V
                        DD
                    Temperature: 17.0°C
                    Count: 2
                    Steering Angle: 0.00°
                    Count: 0
                        SteerAng n.Init
Have you tried updating your copy of VCDS to the latest version, clearing the codes and then doing another autoscan as one of the codes appears to relate to low battery voltage.
Cheers for that Liger will try and find somewhere i can download the correct version, the low battery might be because i have just fitted a new battery and it might need a good run.  would you know the best place to get a alarm Siren for a Skoda  Octiva 2011 as mine has packed up and Skoda want £125+vat for there one?
Ali Express, about $40 delivered, UK breakers on E-bay from £10 but they probably have a dead battery inside them about to leak on the circuit board like yours and mine have no doubt.
Mine shows up a fault code for the siren but thats because its completely foutu and the CCM couldnt detect it, its removed now (to repair but it was beyond help) and I'm pretty sure that the low speed resonance that I have had since is the sheet steel housing bracket vibrating without the mass of the horn module to change the resonant frequency.
I am going to hedge my bets and buy a £10 second hand one then solder in a new battery pack, I can only find 150 and not 200mah ones but it should work OK, if not I would rather have no back up cell pack than one that will leak and destroy the circuit board.
Edited by J.R.
You can download the latest version ftom the Ross-Tech website http://www.ross-tech.com/vcds/download/
hi J.R do you know the part number i need for AliExpress?
