Obd eleven afs :(
Afternoon all, purchased and obd eleven & thought I'd try it out today, put everything back to the way it was but now I get an error for the cornering light (afs), looking for some help regarding it all or I'm happy to travel to someone who is abit more clued up to sort it.
One of the cornering lamps hasn't blown has it? That can cause the afs error message
I'll have a look tonight on my break from work and check all bulbs are working, hopefully that'll be the problem if I'm honest.
Edited by shiznmatt
Just in case you need it, there is a map of VCDS owners via the link below.
Hi jeff, thanks for the reply, I expect I will need it as I'm not touching it again if it's not the bulb.
u can never "put everything back to the way it was" once things have being tampered/modified/changed with OBD11.
if there was a blown bulb - u would get a bulb blown message.
not a cornering light (afs) error.
anywayz - good luck with urs and hopefully u can get it back to normal.
obd11 has a history of your modifications in the app. Click on the car and then History button.
If you have made changes to your car using obd11 then it stores what you did.
