VCDS changes
Hi all,
I'm having a few problems coding my 66 plate vRS. I've fully followed the destructions for enabling main beam assist and I keep getting an error message when I cycle the car. Are there new adaptations on my model year that aren't in the destructions. Also, I can't get teardrop wipe to work either.
I've successfully coded traffic sign recognition and coding out led reg plate lights, so I'm a bit stuck.
Can anyone help?
TIA
Alan
Start by posting a full autoscan and adaption maps for the relevant modules :)
I'll do this when I finish work later today. Thanks
Once the scan is up we can see if the coding is correct, otherwise you may have to go to the headlight module (55) and reset the basic settings to clear the fault.
Just a quick update. Managed to sus out the teardrop wipe. That's now working. Will post up the scan later on.
Thanks for the replies so far.
