ABS issues
Hello. I'm having a few issues. A few weeks ago out of the blue 3 lights popped up on the dash. ABS, t/c esp, tyre pressure warning. A scan revealed rear left wheel speed sensor fault. So, fitted a new abs sensor but while I was fitting it I Noticed the magnet looked a bit rough. So put the car back together as I didn't have a new hub/bearing assembly. The fault returned as i set off. I do now have the part ready to go on. Now having read through the abs control unit thread it's now making me think it could be a faulty unit. But that shows a G201 fault iirc. Just some advice or heads up before jumping up and down on breaker bar to crack the centre hub nut loose would be very much appreciated!!
Edited by meaty101
