Random play from SD card?
Hi,
I've had a good look around but can't find an answer to this so here goes. I've a 2016 Citigo with a swing radio. I can play music from an SD card no problem but how do you make it play tunes randomly. On my previous Suzuki Swift you just pressed the 'random' button, easy. I've just been going round in circles and it just plays in alphabetical order.
Any suggestions would be appreciated, cheers.
Sussed it out myself. I was downloading the files on to the SD card via Windows Media Player which was causing the problem. It was loading them as separate files with an album counting as one file so mix would only randomise the content of an album, not everything. Instead I loaded each track individually onto the SD card direct rather than through the media player so they are all separate files and it now works. Time consuming but at least it works.
