Handbrake button came off
For me it is the rod that is broken, I'm assuming at the end as a new button didn't help. It IS ratcheting though, so I'm wondering if it is the rod I need to replace and if so where to get it as I don't know what part I'm looking for here?  OR is it a whole new handbrake?
Cheers.
G.
On 02/01/2024 at 19:59, hantusk said:
Thanks you so much lex131. I took your sketch, and modelled it in 3d, and printed it on my 3d printer - worked perfectly! I uploaded the 3d model here, for others to 3d print: https://www.printables.com/model/704088-handbrake-button-fix-skoda-octavia-mk-iii-2013-202
thanks guys.
For me I had to remove 1.5mm of the tip for it to go in (last step) otherwise it would brake before it clicked in.
Could be my 3d printer tolerancing that isnt great ?
anyway, thanks very much, and if someone else is struggling with the 3d print try removing 1.5mm of the tip
On 13/12/2019 at 22:05, lex131 said:
You cannot break it. It's a metal thing that will not come out of the handle. You have to pull it like 3-4 cm out. Mine was extremely free inside there and it's slippery also, it's a bit hard to hold on to it and keep it pulled but there is no way you could break anything.
That black stick connects with the button. The spring then pushes the button outside of the lever and the button pulls on the stick and keeps that tension constantly. When the button falls, the spring has nothing to push on, the button lets go of the stick so the stick falls back into the lever.
When the hand brake used to work, remember - when you wanted to release the brake you pushed on the button = you pushed the stick inside and the brake was released. Now the stick is always inside = it's like the button is always pressed so the brake doesn't work.
That's why you need to use one hand to pull the stick out, as far as it goes (it's not elastic or something, it's very clear when you pull exactly how far it goes, you don't need to tense your muscles or something) and with the other hand raise the brake - you should hear and feel those clicking noises and the brake should work.
IF IT DOESN'T then a new button won't solve anything as something else is broken inside (maybe the cable broke).
Have a great weekend!
Maybe I'm oversimplifyming this, but I've found another way to test this before repair.
If I put the original button back over the black bit, and use it to engage the handbrake, it stays up... so I know it's working and just a button problem.
There's a hole on the underside of the plastic button (as in your diagram above) suggesting that a retaining clip has broken, or similar.
On 13/12/2019 at 20:05, SirScott said:
Hi Lex131,
Thanks again.
I have ordered a new one (around 10€ delivery incl) just for backup. :)
You write that i should “pull out the black stick from inside the lever” to check the handbrake - could i pull it too far and break something or can i pull it all the way out?
Does the new one come with a retaining clip, or just the handbrake button itself?
I don't have metalwork skills nor a great deal of time this month (it's a busy work month for me) so I might just bite the bullet and pay a dealer... but I'll report back if I find another solution.
I've had similar failure recently and also furiously searched this forum.
There is a single point of failure where the plastic retaining pawl that holds the button inside the lever can break, which means the button (which is not broken) comes off, because it is under spring pressure.
You may think it's not much of a big deal, because maybe you think it's push to release the ratchet, and the ratchet is engaged "all the time". Well wrong, because without the button attached to the plastic pawl, it can no longer "pull" the rod mechanism forward (under spring pressure remember) and it won't engage the ratchet when you pull up. It is the inverse - the ratchet is NOT engaged by default and the spring pressure (forward pull) is required to engage the ratchet. You push the button to counteract the spring pressure thereby releasing the ratchet. Somewhat counter-intuitive.
This is where that driving myths of "don't press the button when pulling up the handbrake" has a sliver of truth for this engineering scenario. I come from school of using handbrake button all the time because it's quieter and I use handbrake with clutch control at junctions / slow traffic.
In my case, due to urgency , safety assurance, and no time to fiddle around with DIY repairs (blue tack worked temporarily), I had the handbrake lever replaced so it was pricey.
I asked to keep the old lever (because it's expensive!) but also so I can have a look / take photos. I will report back if there is interest.
In summary, yes you can replace the button only, but if the button is not broken, it will be the plastic pawl inside the lever. In my opinion the failure has a grossly disproportionate negative effect on driving safety or quality. If you do not want to DIY repair, you will have to replace the whole lever.
Edited by Xenon1024
clerical clarification
On 19/06/2024 at 13:25, gon said:
thanks guys.
Thanks gon - I just saw your design tweak here, and updated the file already on printables per your change - glad to hear it worked for you in the end!
Edited by hantusk
spelling
So... I was short of time and tools, so I took it to Vindis in Cambs expecting a whole handbrake and a £300ish bill... and paid £81 for a repair. Okay, it's expensive for a button but missing work to sort it out and buy tools would have cost me more, I think.
Seems to work okay for now, will report back if not.
Edited by thinkblueskies
Typo
Hi all
3d printed part kept braking after a few months (maybe my 3d printer is a bit crap)
Tried to do steel bit but failed to make it fit. So in the end opted for another solution.
Drilled shaft (1.5mm)
Drilled an m8 nut to 8.5mm
Drilled an m8 washer to 8.5mm
Fitted spring, then washer, then nut (as spacer) then solid cooper wire through 1.5mm hole to hold it all in place
System now works withou button.
But to make it pretty butchered the inside of the button and shortened it, then added  a dab of glue inside.
Zip tie end underneath is to hold button whilst glue sets.. Will pull it out once set.
Let me know if yous interested in more detailed instructions.
Edited by gon
  • 5 months later...
Almost 6 years later and this post is still going :) Happy i was able to help. P.S.  the metal contraption I made is still working by the way, no issues since the fix.
  • 8 months later...
This happened to me and worse, the plastic clip (underneath the black plastic rod) snapped off, so I decided on a different approach.
Bought 16mm M2 csk stainless machine screws (though 10mm would be plenty). I drilled and countersunk the silver button (2.5mm drill plus countersink bit).
I also bought M2 nut inserts - these were harder to find and I eventually tracked some down on Ali Express. I then drilled the black plastic rod (3.2mm drill or 3mm drill if you wiggle it a bit). You can still apply the handbrake by lifting the handle and pulling out the rod at the same time. This holds it still, so it's easier to drill.
Apply the nut insert underneath the rod (this is fiddly and you may loose one or two before you can squeeze it home with some pliers)
Then apply the spring and the button and carefully screw the csk screw. You may need a tiny hex screwdriver too.
The button - with M2 screw:
The rod, with nut insert fitted:
The re-assembled hand-brake:
The nut inserts:
Edited by webweasel
  • 6 months later...
My handbrake button pinged off a while ago and after buying a replacement I realised I've lost the spring that goes underneath the button... I've not had much success with trial and error trying various springs - does anyone know what size the spring is that normally sits behind the button?
  • 4 months later...
Had the same issue August 2026, ordered new button from skoda parts direct £20 (now asking £40 ?). Dealer wanted £44, so aware of problem and said they had not had to replace whole hand brake only replace button. I had read all posts, so not sure new button would work, but knew to pull control rod out to get ratchet to work.
Guess what, yep failed, on a hill in the dark in slow moving traffic Sept 2026. Did not actually see button go when released the hand brake, doing multiple stop and move on, up hill. Reached down to pull brake and felt no button (dont press on pulling). I pulled the control rod out and pulled the handbrake at same time. Wife put hazards on for me and we had to let traffic pass, before trying to move off. Reported as safety issue to central skoda, clearly other manufacturers recalled on similar issue e.g VW T5.
Dealer charged £115 investigation fee for known issue, plus £440 (£249 + vat for whole hand brake) to fix, two bits of plastic failing. Skoda parts, which is Skoda, £191, but dealer has to use TPS. Like other gent, needed car fixed quickly. I've raised safety issue with DVSC. All need to do this. Some customers get lucky with new button. But it's an un safe design. We found button and spring in back of car. Dealer said car was unroad worthy...so clearly unsafe.
I would have gone small claims, but apparently got to go ombudsmen, they have it sawn up, apparently its dealer not manufacture if wear and tear, but it's a issue with the design in my mind.
oh and I've done less that 58k...so less than original warranty distance.
Rant over ....did buy gorilla glue ...should have used.
Edited by pijhol
Sorry Dog with a bone,
 The parts catalogues show:
Period
Handbrake lever
Early Mk3
5E0711301B — plastic handle
Early leather version → 17 Aug 2015
5E0711301C
From 17 Aug 2015 →
5E0711301D
Clearly issue with pre Aug 2015 handbrakes.
Those that had issue, was your Octavia built pre August 2015. Can any one who had issue post Aug 2015 build post please, so that I can discount it.
Mine was registered Jan 2015, and yes only done 58k miles. Very really parked on hill.
Edited by pijhol
I posted in 2024 on this thread above with my experience. I see that others are affected by it. I went back in my garage to find my old handbrake to take photos, because it is not intuitive how the handbrake works until you see its insides.
My car is 65 plate, delivered Nov 2015, leather version (SE L).
My problem was that the plastic pawl was broken, NOT the button.
See attached photos.
  1. Broken Plastic pawl. This ATTACHES to the button, with a spring underneath. The spring pressure acts on the button to PUSH it, and therefore the plastic rod FORWARDS.
  2. Sideways view of plastic rod inside the handle. The rod attaches to a Claw (grey colour) via a pivot (shiny silver colour). This picture simulates the Button Pressed, Rod pushed back, the Claw is disengaged from the fixed ratchet (black colour).
  3. This picture simulates parked position. Button is not pressed, Rod is pushed forwards under spring pressure, the claw is engaged onto ratchet.
  4. This picture simulates button OR pawl failure (or just pressing the button). Without the button or spring, there are NO forces acting on the plastic rod at all, pulling it forward or back. It will be luck whether it engages with ratchet at all. It is easy for the plastic rod to "fall" backwards, this disengages the claw from the ratchet. Note the claw and ratchet is greased.
  5. Label on the handbrake assembly that was removed. So you see I had the 5E0711301D manufactured 11/09/15 and it broke in 2024. Very similar to how others found it, button and spring randomly in cabin.
Hopefully that helps others understand what is happening. This is why I said in my original post it is not intuititve how the handbrake works because of the way the button and spring interacts with the plastic rod. Lose the spring, you lose the ratchet engagement, and you lose functionality.
I still maintain it is a ridiculously non-proportinate critical failure: a tiny plastic breakage of the button or plastic pawl leads to a significant safety problem. You can replace a broken button relatively simply (it is actually an instruction to do this when replacing handbrake cables) but with a broken pawl, you will need to replace this assembly.
For those budding engineers, this is a good study in FMEA/FMECA.
Sorry, in the previous post I wrote report to DVSC when I meant DVSA.
They came back with the response that because I did not lose control of the car, it is not a recall issue. They ignored the fact that if I had stalled the car on the hill, then I would not have been able to restart it due to needing to press the clutch and maybe the accelerator at the same time... so requiring me to release the foot brake, or at least juggle my feet.
ignored no warning of pending failure, or anyway to exam, if on minor slope then could have left car with hand brake on engaged, other vehicles with handbrake failures have had recall (suspect larger % of vehicle population reported that they failed)
I have put in a FOIR to the DVSA for the number of reported cases and what discussions have been made with Manufacture about the issue. The FOIR has been delayed while they consider if it is subject to Section 31 (either there is a case pending, or they don't want to show negligence on their part and not in public interest????).
I have my original handbrake and a the new button I bought and garage used to test it did not fix problem. I've since put button on and it will now not flick off, although it did the first time I tried it when I got it home, go figure.
Please report to DVSA, numbers matter, especially if car rolled or felt lost in dangerous situation
I found a Skoda document API 11/2014, online showing changed something in 2014 (CW14/2014 Introduce a fixture to fit the locking mechanism at manufacturer).
  • Symptoms: The handbrake button unexpectedly releases, causing the internal spring to fall out. Because the internal pawl can no longer lock into the ratchet teeth, the handbrake lever fails to stay up and defaults to the "brake not applied" position.
  • Cause: Structural damage or clearance issues within the leather sleeve assembly allowing the locking mechanism to unseat.
  • Factory Fix (CW14/2014): Škoda introduced a dedicated manufacturing fixture during Calendar Week 14 of 2014 to ensure the locking mechanism is perfectly aligned and secured during assembly. Vehicles suffering from this failure typically require a full replacement of the handbrake lever assembly.
They won't confirm anything in writing about how many they have seen, what got altered in 2014, but some good will given.
