some unknown VCDS errors, help needed
Im struggling to finds these codes its a 2.0TDI 184
o ASAM data for: "EV_ECM20TDI01140L906021EL" (SK37)
4 Faults Found:
5211 - ROD - Unknown Error Code
          - 00 [096]
          Intermittent - Not Confirmed - Tested Since Memory Clear
17158 - ROD - Unknown Error Code
          - 00 [032]
7150 - ROD - Unknown Error Code
          - 00 [032]
5243 - ROD - Unknown Error Code
          - 00 [229]
          MIL ON - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
thanks in advance.
the errors clear but the car periodically goes back into limp mode.
Is your VCDS up to date and have you got a full autoscan?
