Obd 11
Hi all
i have a 2018 2.0 tsi scout and was wondering if I could switch on tsr and high beam assist my car has the camera in the screen
I did do both on my superb
thanks
mark
Edited by Windscreenman
Check out the octavia MKIII forum for coding.
Most of the options you are able to do on the octavia can be done on your bear.
I enabled traffic sign recognition on my edition using OBD11
Thank you
I will check it out
Is there anything else that can be coded using OBD 11??
once I get my Kodiaq I may look into getting a few bits switched on...
Just watched a video on YouTube this morning about this. I've just ordered a Kodiaq Edition and saw that I should be able to enable lane assist and high beam assist because I added the traffic sign option.
No such features on my current Superb, but I might order a dongle anyway in preparation.
Install the app on your phone and choose the Kodiaq. All the canned changes are listed as well as guidance to code yourself. Bear in mind you need various hardware present to achieve some of these.
Edited by jasoncmiles
Thanks for the tip.
I've no idea about exactly what OBD11 can do, but this is a Google-translated list of what may be possible to achieve using VCDS, according to this Austrian website: https://www.cargrade.at/codierungsliste-skoda-kodiaq-ns/
Coding list Skoda Kodiaq NS (2016 - 20xx)
The following coding list contains all possible VCP / VCDS codes, activations and adjustments that we can carry out with the Skoda Kodiaq NS. If you have questions about specific issues, or would like to have a programming or adaptation of a feature that you do not find on the list, please contact us.
Adaptation of the welcome logo in the on-board computer
Representation of the selected driving profile in MFA (multifunction display)
Adjustment of the tailgate to close with FFB (radio remote control)
Add off-road ad
Show top speed in navigation (with built-in VZE)
Activate Green Drive Menu
New display design (Kodiaq)
Activation of fog lamps (NSW) as cornering light
Adaptation of the speed thresholds for activating the cornering light via fog lights
Adaptation of the dynamic start-up assistant
Passenger mirror lowering when reversing
Subsequent activation of the Hill Hold Assistant
Adaptation of hill start assist
Activate display of the refueling quantity in the on-board computer
Adjustment of the intensity of the brake disc drying
Automatic activation of the CH / LH function
Activate CH / LH only with TFL (daytime running light)
Activate CH / LH via fog lights
Coming home switch-on event (driver's door vs. ignition)
Activation of beeping or short honking when locking and unlocking the vehicle
Activate the visual display of the parking aid via the audio or navigation system
Adaptation of the shutdown speed of the parking aid
Parking assistance safety distance
Adjustment of microphone sensitivity
Activate release run of the windows when opening the door
Enable high beam assistant
Adjust Speed Threshold for High Beam Assistant Activation
Prevent Reset / Reset High-Beam Assistant
Enable freeway light at high speed
Disable Gurtwarner
Adjustment of the heating time of the rear window heating
Adaptation of the light switch-on threshold of the headlights
Deactivation of the tear-wiping function of the front / rear wiper
Display of the comfort wiping function of the rear window wiper in the CAR menu
Automatic locking, locking, locking the vehicle
Display of the fan speed in AUTO mode of the air conditioner
Adjust the comfort indicator cycle
Subsequent unlocking of the Lane Assist - Lane Keeping Assist
Adjustment of Lane Departure Assist of Intensity Steering Assist, Intensity Steering Wheel Vibration, Deactivation Threshold Driver Inactivity
Activation of the lap timer
Display of the oil temperature
Sunroof (SAD) - Panoramic glass roof Activate comfort opening
Activate rainproof function
Activation of reversing camera (RFK)
Storage of the last set seat heating level
Adjustment of the temperature setting of the respective seat heating stages
Adjustment of seat heating return thresholds
Disabling or adjusting the volume of the structure-borne sound actuator
Adaptation of the radio mode of the Spiegelanklappung
Extension of the activation interval of the headlamp cleaning system for the front washing system
Delayed response of the headlamp cleaning system for the front washing system
Activation of the parking light of the taillights for the (LED) daytime running light
Activation of the fog lamps (NSW) in addition to the daytime running lights
Deactivation of the daytime running light with the handbrake pulled
Activation of the daytime running light function only in switch position Auto on
Possibility to deactivate the daytime running light in the CAR menu
3. Brake light as receipt ZV
LED daytime running lights do not dim when flashing
LED daytime running light dimming when flashing
Fog lights as flashing lights when no low beam is active
Dimming the hazard switch
Activate AFS (Adaptive Headlamp) (only possible with Xenon with dynamic cornering light)
Activation of the ambient lighting even when the exterior mirrors are folded
Adjust consumption display (FIS)
Activation of the warning with active rear fog light
Activation of the warning when driving with active parking light
Activation of the traffic sign display
Activate pointer test / pointer deflection / staging
Deactivation of the message / continuous tone at ignition on
Adjust ESP mode (complete deactivation possible!)
Deactivate Start Stop
DVD / video image activation while driving
Unlock "alarm system" (without sensors)
Lock the car even though the engine is running (only with Kessy)
Activation of Trailer Assist
Not sure about Lane Assist, as you would need to have the rear radars fitted. I wouldn't bother with high beam assist, it's rubbish IMO, and I've switched it off after being fed up of dazzling other drivers.
EDIT: Of course there are multiple parts to lane assist, I forgot. So Lane holding assistant (or lane departure warning) should be fine, but lane change assistant won't without those radars.
Edited by lowedb
It’s a bit hit and miss - it works really well on fairly straight A-roads, but on narrow twisty B-roads it doesn’t sense drivers coming round bends all that well because their lights are not straight ahead, and it also then doesn’t put the high beams back on if you’ve slowed down to pass another car until you’ve sped back up to the activation speed (about 37mph). I don’t think I’d pay for it as an optional extra, but if you can enable it for free* then why not?
Lane Assist is purely the “keeping you in the lane you’re in” thing. The other system you mention there is the Blind Spot system, which as you say requires the rear radars, but also has the warning lights in the side mirrors.
