Abs coding help
Hi
Could anyone provide me with my abs code if I supplied the part number and my chassis number
Tia And happy new year
Possibly. Post a full autoscan to start with.
Why has it lost the code and do you have a previous scan?
22 hours ago, jdamarine said:
Hi
Your details state you have a Fabia Vrs; are you sure this is in the correct section?
Thanks, I don't have  a scan , And like a plonker I tried to swap the cluster with another one, I have lost the abs long code
Sold that a few years ago
Swapping the cluster would do it ;)
When you're able to, post a full scan...
Saturday,29,December,2018,11:46:05:27636
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.4 (x64)
Data version: 20181017 DS296.0
www.Ross-Tech.com
VIN: TMBME75L5B6043358   License Plate:
Mileage: 255850km-158977mi   Repair Order:
Chassis Type: 5L-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 52 55 56 62 69 72
          77
VIN: TMBME75L5B6043358   Mileage: 255850km-158977miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFJA)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BS    HW: 03L 906 018 BR
   Component: R4 2.0l TDI   H23 9978
   Revision: 42H23---    Serial number:
   Coding: 00190012042700080000
   Shop #: WSC 25031 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018BS 003007
   ROD: EV_ECM20TDI01103L906018BS_003.rod
   VCID: 7CF7B483F78093AA87-8028
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 00000000000000000000000000000000000000
   Shop #: WSC 33361 790 00999
   VCID: 76E3A6ABC1ACC9FAF1-8022
4 Faults Found:
01042 - Control Module; Not Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 188
                    Mileage: 255855 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 3
                    Count: 2
                    Count: 4096
                    Count: 195
                    Count: 37120
                    Count: 0
                    Count: 256
                    Count: 0
01435 - Brake Pressure Sensor 1 (G201)
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 188
                    Mileage: 255855 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 3
                    Count: 2
                    Count: 4096
                    Count: 279
                    Count: 40448
                    Count: 0
                    Count: 256
                    Count: 0
00778 - Steering Angle Sensor (G85)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 188
                    Mileage: 255855 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 3
                    Count: 2
                    Count: 4096
                    Count: 295
                    Count: 40448
                    Count: 0
                    Count: 256
                    Count: 0
01423 - Lateral Acceleration Sensor (G200)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 188
                    Mileage: 255855 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 3
                    Count: 2
                    Count: 4096
                    Count: 270
                    Count: 40448
                    Count: 0
                    Count: 256
                    Count: 0
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 BE    HW: 3T0 907 044 BE
   Component: Climatronic   H16 0402
   Revision: 00006001
   Coding: 0000000002
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 76E3A6ABC9ACC9FAF1-8022
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 086 H    HW: 1K0 937 086 H
   Component: BCM PQ35  M   103 0615
   Revision: 00103 AD
   Coding: 48000AB8E05BF1C040080080110089E4437400AE726D85605C8540000040
   VCID: 356161A79C2A82E238-8060
   Subsystem 1 - Part No: 5L2 955 119 A  Labels: 1KX-955-119.CLB
   Component: SK356  26  0604
   Coding: 00F7B5
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 040211 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
1 Fault Found:
00907 - Intervention load Management
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 228
                    Mileage: 255855 km
                    Time Indication: 0
                    Date: 2018.12.29
                    Time: 18:34:36
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.10 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32991103654449
   Coding: 108013
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000_001.rod
   VCID: 33655FBF9A5E9CD216-8066
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Component: AirbagVW10    013 0613
   Serial number: 003G5RA09HYZ
   Coding: 00005442
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 316955B76042AEC264-8064
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME1D74015CZZZ-
   Crash sensor for side airbag: front passenger side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME3D77015CZZZ%
   Crash sensor for side airbag: rear: driver side:
   Component: S.Sens.Fahr.H  --- ----
   Serial number: 3512QSME78370311ZZZL
   Crash sensor for side airbag: rear: passenger side:
   Component: S.Sens.Beif.H  --- ----
   Serial number: 3522QSME44290311ZZZG
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110206300939
   Coding: 108A140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79F9AD97F8B2A6829C-802C
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 820000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 5L0 920 940 H    HW: 5L0 920 940 H
   Component: KOMBI         H21 0420
   Serial number: 00000000000000
   Coding: 420E00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 040211F1001657
   Coding: 356303
   VCID: 306F50B36348A7CA6B-8064
Address 22: AWD        Labels: 0AY-907-554-V1.clb
   Part No SW: 0BR 907 554 B    HW: 0BR 907 554 B
   Component: Haldex 4Motion      3017
   Coding: 0000005
   Shop #: WSC 00000 000 00000
   VCID: 44870C6307F02B6ABF-8010
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H21 0420
   Coding: 000000
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB82DB8D141D1A65-803E
Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
   Part No SW: 7N0 959 793 E    HW: 7N0 959 793 A
   Component: TSG FA        H04 0400
   Revision:             Serial number: 0000012023434
   Coding: 011502208001231004
   VCID: 44870C63C7F02B6ABF-8010
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   VCID: 34675CA357509BEA0F-8060
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
            005 - No or Incorrect Basic Setting / Adaptation - MIL ON
             Freeze Frame:
                    Fault Status: 11100101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 255855 km
                    Time Indication: 0
                    Date: 2018.12.29
                    Time: 18:28:40
             Freeze Frame:
                    Battery Volts: 10.5 V
                        PD
                    Temperature: 14.0°C
                    Count: 3
                    Steering Angle: 0.00°
                    Count: 0
                        SteerAng n.Init
Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
   Part No SW: 7N0 959 792 E    HW: 7N0 959 792 A
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000012130975
   Coding: 011500208001231004
   VCID: 43850F7FC2FE2C5286-8016
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0148
   Revision: 00H04000    Serial number:
   Coding: 3704091
   Subsystem 1 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0008
   Coding: 00000056
   Subsystem 2 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0008
   Coding: 00000056
1 Fault Found:
02988 - Left-Hand/Right-Hand Traffic Switchover Active
            000 -  -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 188
                    Mileage: 255855 km
                    Time Indication: 0
                    Date: 2018.12.29
                    Time: 18:28:41
             Freeze Frame:
                    Voltage: 10.93 V
                    Speed: 0.0 km/h
                        ABS 1
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1Z0 035 156 G    HW: 1Z0 035 156 G
   Component: BOLERO        015 0029
   Revision: -----29S    Serial number: SKZ4Z3L1105846
   Coding: 0D0004000001
   VCID: 366366AB812C89FA31-8062
Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-795.clb
   Part No SW: 7N0 959 795 D    HW: 7N0 959 795
   Component: TSG HL        H03 0400
   Revision:             Serial number: 0000012189111
   Coding: 010000200001531004
   VCID: 45811167CCCA1262A8-8010
Address 69: Trailer
Cannot be reached
Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-795.clb
   Component: TSG HR        H03 0400
   Revision:             Serial number: 0000012188898
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 5K0 035 730     HW: 5K0 035 730
   Component: TELEFON       H09 1020
   Revision: 1B001001    Serial number: 00007669332561
   Coding: 0200000000010110
   ASAM Dataset: UHVNA A01009
   ROD: UHVNA.rod
   VCID: 62CBEAFB7524455AAD-8036
End-------------------------(Elapsed Time: 02:55)--------------------------
Address 44: DTCs cleared
Address 03: DTCs cleared
Control Module Part Number: 1K0 907 379 BE
  Component and/or Version: ESP MK60EC1   H31 0108
           Software Coding: 00000000000000000000000000000000000000
            Work Shop Code: WSC 33361
Advanced Identification
     Identification: TT1-000
     Revision: 00H31001
     Date: 28.12.10
     Manufacturer number: 0104
     Test stand number: 1181
Flash Status
     Programming Attempts(application): 0
     Successful Attempts(application): 0
     Programming Status: 00000000
     Flash Date: 2000.14.00
     Flash Tool Code: 00000 000 00000
Misc.
     Hardware number: 1K0 907 379 BE
     Workshop System Name: J104
VCDS Info:
       Labels: 1K0-907-379-60EC1F.CLB
     Revision: 00H31001
     Date: 28.12.10
Flash Status
Misc.
VCDS Info:
                Address 03: ABS Brakes  (1K0 907 379 BE)
12:14:31
  OFF   ABS Warning L. (K47)
Address 03,1K0 907 379 BE,recoded (Long Coding),from,00000000000000000000000000000000000000,to,05000000000000000000000000000000000000,(33361/790/00999),
Address 03,1K0 907 379 BE,recoded (Long Coding),from,00000000000000000000000000000000000000,to,0000000002,(33361/790/00999),
Address 09,1K0 937 086 H,recoded (Long Coding),from,48000AB8E05BF1C040080080110089E4437400AE726D85605C8540000040,to,00F7B5,(33361/790/00999),
Address 09: DTCs cleared
Address 09,1K0 937 086 H,recoded (Long Coding),from,48000AB8E05BF1C040080080110089E4437400AE726D85605C8540000040,to,0730ED,(33361/790/00999),
Address 09,1K0 937 086 H,recoded (Long Coding),from,48000AB8E05BF1C040080080110089E4437400AE726D85605C8540000040,to,00000AB8E05BF1C040080080110089E4437400AE726D85605C8540000040,(33361/790/00999),
Address 03,,recoded (Long Coding),from,00000000000000000000000000000000000000,to,0000000002,(33361/790/00999),
A quick google found similar yeti's with these ABS lcodes - these will not work in your Yeti:
933F400E092701FBC91302E5901F808A310000
933F400E092201FAC90D02E7901E808A310000
933F400E09260102C91302EA9022808A300000
Based on those, I would try this first:
933F400E092601FDC90E02E99021808A300000
Not sure if your car originally had indirect TPMS, HHC or XDS. Looks like the ABS pump can support all three so assuming the above worked, try:
933F400E092601FDC90E02E99021808A350800
Let us know how you get on. Also, are you aware you've got the headlights set in travel mode for driving abroad? :)
Our 2014 L&K 2.0 TDi (170) manual Yeti was:
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
Coding: 963F600E092601FE691206EC901C808AA1015023
HOWEVER it must be said that ‘just’ copying and pasting someone else longcode isn’t the best way of doing it, personally I would triple check the above code is relevant to your car BEFORE saving it!. (mine is also later part number)
Thanks guys really appreciate this
