Help required with some error codes
Hi i have just fitted an alarm siren and ran VCDS good start it cleared the error code for the alarm, bad news i now have these 2 coming up and not sure what they are for any help much appreciated
Address 01: Engine (CAX)       Labels: 03C-906-016-CAX.clb
   Part No SW: 03C 906 016 E    HW: 03C 906 016 C
   Component: MED17.5.5       G   5344
   Revision: LCH12---    Serial number:
   Coding: 0000077
   Shop #: WSC 73430 790 00085
   VCID: 214F95C6F8BE8016B43-8074
2 Faults Found:
001674 - ECM Power Relay Load Circuit: (J271)
               P068A - 000 - De-Energized Performance Too Early - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
                    Date: 2047.15.31
                    Time: 31:63:63
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 9.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 8.509 V
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 3
                    Reset counter: 255
                    Time Indication: 0
                    Date: 2047.15.31
                    Time: 31:63:63
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 12.0°C
                    Temperature: 12.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 9.271 V
Readiness: 0010 0001
I am no expert but they both look low battery voltage related. I would suggest that you make sure the battery is fully charged, clear the codes and see whether they come back.
Fitting my Ali-Express alarm siren did not clear the fault code and I now have an additional one for the interior monitoring sensor :sadsmile:
It will have to wait for warmer weather, cant be doing with removing the unit again to double check the connector.
I'd agree for checking battery and charging system.
Seems to struggle with to low voltage the system.
got to admit it was cold and wet when i did mine yesterday, but wanted to make sure it worked in case i need to take it back lol, good luck with your one.
