Adding BT module to swing stereo.
As mentioned above, need help to connect the module +/- cabelsnto the right place.
Got two red/white cables in the iso and one brown.
Correct me if I'm wrong.
Brown is -
Red/white +
But the stereo does shut down when I turn of the key. But if I measure, I got 12v on both labels even if key are on ignition and when its out.
English isn't my main language. So sorry for bad grammar.
If I read this right, you're getting 12v even with the car switched off? This is because the stereo isn't switched on/off by power/ignition key (like old cars) it's done by CANBus instead.
Unlike the old (easy) ones, you can turn the key to '0' and the stereo will still run, it's only when you remove the key that it should switch off.
