Serpentine belt chirp?
I noticed that my serpentine belt started to chirp, i sprayed some water on the grooved side, and stopped the chirping for a while, but later started again.
Can this be the belt, or the tensioner?
Here, i made a video what exactly happening.
https://www.youtube.com/watch?v=5te12uVAT8E
Most probably just glazed from age and dust etc.
I've found pouring a couple of litres of very hot water with laundry detergent on the inner ribbed surface whilst the engine is running then rinsing with a garden hose works to clean up the belt and stop the noise.
The only real cure is a new belt
I think Gater recommend a new one every 4-5 years but that@s overkill(usually)  as they wear they run on the base of the grooves instead of biting on the micro V's   a good chance to check the tensioner pully bearing (and grease if necessary)  while it's  off
