Fault codes
I don't know for sure as I'm no real expert but, with that crop of faults, the first things I would be looking at would be the wiring in the elephant's trunk to the boot lid for broken/damaged wires and that the earth point the stuff in the boot lid is connected to isn't corroded.
Do you have a test meter? If you go from bare metal in the boot lid (for example the bolts that hold the wiper motor) and the body of the car, what resistance do you measure?
Cheers. Not sure about that as it's the front wipers causing the main problem. With the weather as it is, can't use the car.
