Getting worse
Hi guys, tried to change a few things using VCDS. Every time I open it I seem to get extra faults. Started off getting the wipers not working and it progresses to extra ones each time. Current fault codes are attached. Any help would be very much appreciated.
Log-TMBBK21Z5A2015448-163520km-101606mi.txt
Lol. Not very helpful, but definitely accurate apart from the timeline. Started last week!
I don't suppose you have a log from the car before you started changing stuff?
And you should update your VCDS... ;)
Edited by Rustynuts
Nope, unfortunately not. Hopefully will learn from that mistake! VCDS was only downloaded yesterday so assumed it was the most updated version.
Sorry, yes.  I read the time of the scan 17.43 as the version number. You're up to date now I have my glasses on.
If you look in C:Rosstech/logs you might just find the initial scan there. You did actually do a scan before you started playing, didn't you?
