2012 mk2 1.6 idle speed issue
Hello
I need help! I have a mk2 Škoda Octavia 1.6 mpi (face lift) idle speed issue. I got the O2 upstream sensor replaced, and ignition coil pack changed, as well as the spark plugs. A small leak in the brake vacuum line was repaired, injectors and throttle body cleaned, but once optimum temperature is attained, engine sputters when car is stopped. Idle speed is low, especially when air conditioning is off! There are no error codes when scanning is done. Does anyone have any idea what the problem is, and how to resolve this?
