Hunter wheel alignment
Hi, just a quick question. Does hunter wheel alignment do alignment plus geometry? If not do you know what machine does a full geometry? Thanks
I believe so. Our local National tyres has got a new (non Hunter) alignment machine which showed camber, caster and toe in. Had swmbo Getz set up checked after repeated kerb ramming. Feels much better. £32 to adjust and a check is "free".
Thanks for replying. I've had roughly 5 sets of tyres on the front and all of them have scrubbed on the inside, i've been to a different tyre place each time to no avail so I'm really hoping a place with a hunter machine can sort it this time. Thanks again
@Tomjones1995 - Well, I'd suggest starting by checking the front ride height, because if that's low you'll be running too much front camber, and that will wear the inside edges.
I'll definitely mention it when I get it checked thanks
Also, are there lots of 'sleeping policemen' in Welshpool ?
No hardly any to be honest but there's loads and loads of pot holes
